Ga door naar hoofdinhoud
Apple Powerbook 520/540 General Disassembly
Wat je nodig hebt
  1. Apple Powerbook 520/540 General Disassembly, Case: stap 1, afbeelding 1 van 2 Apple Powerbook 520/540 General Disassembly, Case: stap 1, afbeelding 2 van 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: stap 2, afbeelding 1 van 1
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - Antwoord
    The Screws are T8!
    Willy Kaiser - Antwoord
  3. Apple Powerbook 520/540 General Disassembly: stap 3, afbeelding 1 van 1
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
  4. Apple Powerbook 520/540 General Disassembly: stap 4, afbeelding 1 van 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: stap 5, afbeelding 1 van 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
    Philips PH00 screws
    8-Bit Hero Wendler - Antwoord
  6. Apple Powerbook 520/540 General Disassembly: stap 6, afbeelding 1 van 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: stap 7, afbeelding 1 van 3 Apple Powerbook 520/540 General Disassembly: stap 7, afbeelding 2 van 3 Apple Powerbook 520/540 General Disassembly: stap 7, afbeelding 3 van 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Mark McNeff
497 Reputatie
2 handleidingen geschreven
2 opmerkingen
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Antwoord
Thanks been trying to fix this for a long time
Luke - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 61
Altijd: 6,703
