Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
With the Generally Disassembly completed, you may proceed to floppy drive installation.
Remove the plastic panel at the bottom of the display.
Reverse the computer to access the peripheral panel in the back.
Remove the two T8 Torx screws on either side of the bar code panel.
Reverse the computer to have the monitor and mousepad facing you.
Remove the plastic panel underneath the display.
Remove the three T8 Torx screws securing the floppy drive to the frame.
Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
Lift the defective floppy drive from the body of the computer.
Replace the defective drive with a new drive.
Follow these instructions in reverse order to reassemble the device.
Één opmerking
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
