Ga door naar hoofdinhoud
Apple Pencil (1st Generation) Tip Replacement
Wat je nodig hebt
  1. Apple Pencil (1st Generation) Tip Replacement, Preparation: stap 1, afbeelding 1 van 3 Apple Pencil (1st Generation) Tip Replacement, Preparation: stap 1, afbeelding 2 van 3 Apple Pencil (1st Generation) Tip Replacement, Preparation: stap 1, afbeelding 3 van 3
    • Grab your Apple Pencil Generation 1. Make sure you have replacement tips . You can buy them from Apple or Amazon.
  2. Apple Pencil (1st Generation) Tip Replacement, Unscrewing and Installing the tip: stap 2, afbeelding 1 van 1
    • To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
    • Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
Conclusie
Tay
5.305 Reputatie
30 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 338
Altijd: 2,938
