Ga door naar hoofdinhoud
Apple Airport Extreme Model A1408 Back Pad Replacement
Wat je nodig hebt
  1. Apple Airport Extreme Model A1408 Back Pad Replacement, Back Pad: stap 1, afbeelding 1 van 1
    • CAUTION: The heat gun and hair dryer can get very hot. Do not put your hands or any other body part too close to either device. Also, do not touch the back pad right after heating it.
    • Use a blow dryer or heat gun on a medium to high heat setting on the back pad to loosen the glue that attaches it to the device.
  2. Apple Airport Extreme Model A1408 Back Pad Replacement: stap 2, afbeelding 1 van 1
    • To avoid ripping the back pad, gently peel it back from one corner until the pad is completely off.
    • Use heat in areas where the glue is not loose enough.
    • You may need to reattach the back pad with double-sided tape if the glue is not tacky enough to stick the pad back on.
Conclusie
To reassemble your device, follow these instructions in reverse order without using the hair dryer.
Jada Evers
296 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-37, Amido Fall 2014 Lid van Cal Poly, Team 10-37, Amido Fall 2014
CPSU-AMIDO-F14S10G37
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,002
