Ga door naar hoofdinhoud
Apple AirPort Extreme Model A1354 Antenna Replacement
Wat je nodig hebt
  1. Apple AirPort Extreme Model A1354 Antenna Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 2, afbeelding 1 van 1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 3, afbeelding 1 van 1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 4, afbeelding 1 van 3 Apple AirPort Extreme Model A1354 Antenna Replacement: stap 4, afbeelding 2 van 3 Apple AirPort Extreme Model A1354 Antenna Replacement: stap 4, afbeelding 3 van 3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 5, afbeelding 1 van 1
    • Remove the outer casing.
    • The exposed logic board should look like this.
  6. Apple AirPort Extreme Model A1354 Antenna Replacement, Antenna: stap 6, afbeelding 1 van 1
    • Remove the metal casing by gently prying the logic board away with you hands.
    • This should be pretty easy, you already removed the screws holding these pieces together.
  7. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 7, afbeelding 1 van 2 Apple AirPort Extreme Model A1354 Antenna Replacement: stap 7, afbeelding 2 van 2
    • Turn the device so that the antenna to be replaced is facing you.
  8. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 8, afbeelding 1 van 1
    • Caution: Be careful not to bend the metal strip that the antenna is attached to. This may cause problems during reassembly and use.
    • Using the screwdriver, unscrew the 2.5mm Phillips screw on the antenna.
  9. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 9, afbeelding 1 van 1
    • Turn the device over so that the antenna with the screw removed is still facing you.
  10. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 10, afbeelding 1 van 1
    • Carefully peel back the metallic silver tape covering the cable of the antenna to be removed.
  11. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 11, afbeelding 1 van 2 Apple AirPort Extreme Model A1354 Antenna Replacement: stap 11, afbeelding 2 van 2
    • Carefully peel back the clear yellow tape covering the cable of the antenna to be removed.
  12. Apple AirPort Extreme Model A1354 Antenna Replacement: stap 12, afbeelding 1 van 1
    • Remove the antenna.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brandon
387 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-2, Forte Spring 2012 Lid van Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 Leden
12 handleidingen geschreven
3 opmerkingen
Where do you get a new antenna from?
jimholewka - Antwoord
That's my question too. Where do we get a new antenna and wifi card to correct a poor signal?
jonathan - Antwoord
How will I receive an answer? jonathan@baylis.ca
jonathan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 12,213
