Inleiding
If the base station is sending out a poor signal, an antenna may need to be replaced.
Wat je nodig hebt
First start by peeling off the outer rubbery covering on the bottom of the device.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
4 andere personen hebben deze handleiding voltooid.
