Inleiding
At some point the internal battery may run out of energy and need to be replaced, this guide is here to help you do this. This process and is quite simple and straight forward with the right tools. A 3V CR2450HR battery will be needed before starting.
Wat je nodig hebt
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
Carefully push back the three metal tabs with your fingers on the sides of metal case.
Gently slide out the battery with a small narrow tool such as a spudger. Insert a new 3V CR2450HR.
6 andere personen hebben deze handleiding voltooid.
