Ga door naar hoofdinhoud
Apple AirPort Extreme Model A1034 USB Port Replacement
Wat je nodig hebt
  1. Apple AirPort Extreme Model A1034 USB Port Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 3, afbeelding 1 van 2 Apple AirPort Extreme Model A1034 USB Port Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 4, afbeelding 1 van 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 USB Port Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 6, afbeelding 1 van 1
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 7, afbeelding 1 van 1
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 USB Port Replacement: stap 8, afbeelding 1 van 2 Apple AirPort Extreme Model A1034 USB Port Replacement: stap 8, afbeelding 2 van 2
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
  9. Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: stap 9, afbeelding 1 van 2 Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: stap 9, afbeelding 2 van 2
Conclusie
Michael Garcia
411 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-15, Regan Fall 2011 Lid van Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 3,119
