Ga door naar hoofdinhoud
Apple AirPort Extreme Model A1034 Internet Card Replacement
Wat je nodig hebt
  1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Internet Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Internet Card Replacement: stap 3, afbeelding 1 van 2 Apple AirPort Extreme Model A1034 Internet Card Replacement: stap 3, afbeelding 2 van 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Internet Card Replacement: stap 4, afbeelding 1 van 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: stap 5, afbeelding 1 van 1
    • Remove four 1mm phillips screws from the bottom.
  6. Apple AirPort Extreme Model A1034 Internet Card Replacement: stap 6, afbeelding 1 van 1
    • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Michael Garcia
411 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-15, Regan Fall 2011 Lid van Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Leden
13 handleidingen geschreven
Één opmerking
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 5,133
