Ga door naar hoofdinhoud
Apex TM772 Casing Removal
Wat je nodig hebt
  1. Apex TM772 Casing Removal, Casing: stap 1, afbeelding 1 van 1
    • Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
  2. Apex TM772 Casing Removal: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Moving along the seam continue to pry the case apart.
    • The internal speaker is adhered to the inside of the back casing. There are two wires that connect the speaker to the circuit board and may be damaged if care is not taken. Once open the speaker may be removed from the back casing by removing the tape holding the speaker with either tweezers or your fingers.
  3. Apex TM772 Casing Removal: stap 3, afbeelding 1 van 1
    • The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 155
