Ga door naar hoofdinhoud
Aorus 15P XD SSD Replacement
Wat je nodig hebt
  1. Aorus 15P XD SSD Replacement, SSD: stap 1, afbeelding 1 van 2 Aorus 15P XD SSD Replacement, SSD: stap 1, afbeelding 2 van 2
    • First, make sure the power is off and disconnect the power.
    • Use a Torx security screwdriver to remove twelve 1.2 mm screws from the back case.
    • Use an opening tool to gently separate the front and back case. Work your way around the perimeter of the laptop and undo the clips holding it together.
    • Remove the back case.
  2. Aorus 15P XD SSD Replacement: stap 2, afbeelding 1 van 3 Aorus 15P XD SSD Replacement: stap 2, afbeelding 2 van 3 Aorus 15P XD SSD Replacement: stap 2, afbeelding 3 van 3
    • Use a JIS screwdriver to remove the single 8 mm screw securing the SSD in place.
    • Slide the SSD out of the socket connected to the motherboard.
    • Slide your new or upgraded SSD in the socket securely and replace the 8 mm screw.
  3. Aorus 15P XD SSD Replacement: stap 3, afbeelding 1 van 1
    • Set the back case on the laptop but don't replace the screws yet.
  4. Aorus 15P XD SSD Replacement: stap 4, afbeelding 1 van 3 Aorus 15P XD SSD Replacement: stap 4, afbeelding 2 van 3 Aorus 15P XD SSD Replacement: stap 4, afbeelding 3 van 3
    • Turn the device back on and open the advanced storage settings.
    • Choose the storage used on other drivers.
    • Next, check if the storage you installed is recognized in local disk storage.
  5. Aorus 15P XD SSD Replacement: stap 5, afbeelding 1 van 2 Aorus 15P XD SSD Replacement: stap 5, afbeelding 2 van 2
    • If the storage is detected, replace the screws.
    • If your storage is not detected, open the back case to make sure the SSD is plugged in tightly to the socket. If not, go back to Step 2.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Weitao Shi
142 Reputatie
1 Handleiding geschreven
York University, Team M-26, Allen Summer 2022 Lid van York University, Team M-26, Allen Summer 2022
YORK-ALLEN-SU22SMG26
1 Lid
2 handleidingen geschreven
3Gids Commentaar
Thanks, does the new SSD need thermal pad as well? And if so what thickness?
Martijn Spits - Antwoord
Yes. what thickness is required? and which one is gen 3 and gen 4 slots?
Mark Jose -
I read that the one slot can be used for gen3 or sata, however I don't see where might the sata drive can be placed inside this laptop.
Mark Jose - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 125
Altijd: 6,154
