Ga door naar hoofdinhoud
Anne Pro 2 Keyboard Keycaps Replacement
Wat je nodig hebt
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: stap 1, afbeelding 1 van 1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: stap 2, afbeelding 1 van 3 Anne Pro 2 Keyboard Keycaps Replacement: stap 2, afbeelding 2 van 3 Anne Pro 2 Keyboard Keycaps Replacement: stap 2, afbeelding 3 van 3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: stap 3, afbeelding 1 van 2 Anne Pro 2 Keyboard Keycaps Replacement: stap 3, afbeelding 2 van 2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: stap 4, afbeelding 1 van 1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: stap 5, afbeelding 1 van 1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Omar Sukkar
145 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 2,379
