Ga door naar hoofdinhoud
Anki Vector Belts Replacement
  1. Anki Vector Belts Replacement, Belts: stap 1, afbeelding 1 van 1
    • Raise Vector's arms above his head.
  2. Anki Vector Belts Replacement: stap 2, afbeelding 1 van 2 Anki Vector Belts Replacement: stap 2, afbeelding 2 van 2
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shay Takei
1.570 Reputatie
5 handleidingen geschreven
Cal Poly, Team S2-G6, Maness Spring 2019 Lid van Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Leden
10 handleidingen geschreven
Één opmerking
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 1,186
