Ga door naar hoofdinhoud
Anki Cozmo Speaker Replacement
Wat je nodig hebt
  1. Anki Cozmo Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Anki Cozmo Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Speaker Replacement: stap 2, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
  3. Anki Cozmo Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Speaker Replacement: stap 6, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 6, afbeelding 2 van 2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Speaker Replacement: stap 7, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 7, afbeelding 2 van 2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Speaker Replacement: stap 8, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Speaker Replacement: stap 9, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 9, afbeelding 2 van 2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
  10. Anki Cozmo Speaker Replacement: stap 10, afbeelding 1 van 3 Anki Cozmo Speaker Replacement: stap 10, afbeelding 2 van 3 Anki Cozmo Speaker Replacement: stap 10, afbeelding 3 van 3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
  11. Anki Cozmo Speaker Replacement: stap 11, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 11, afbeelding 2 van 2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Speaker Replacement: stap 12, afbeelding 1 van 1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Speaker Replacement: stap 13, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 13, afbeelding 2 van 2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Speaker Replacement: stap 14, afbeelding 1 van 1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Speaker Replacement: stap 15, afbeelding 1 van 1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Speaker Replacement: stap 16, afbeelding 1 van 2 Anki Cozmo Speaker Replacement: stap 16, afbeelding 2 van 2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Marisa Gay
702 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G8
3 Leden
7 handleidingen geschreven
2Gids Commentaar
Great, do you know where to buy the speaker ?
Gilberto Torres - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 87
Altijd: 2,777
