Ga door naar hoofdinhoud
Anker SoundCore 2 Speaker Replacement
Wat je nodig hebt
  1. Anker SoundCore 2 Speaker Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Speaker Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Speaker Replacement, Speaker: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Speaker Replacement, Speaker: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Speaker Replacement, Speaker: stap 2, afbeelding 3 van 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Speaker Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Speaker Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Speaker Replacement: stap 3, afbeelding 3 van 3
    • The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
8 opmerkingen
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Renato Galindo - Antwoord
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
philcuchetti - Antwoord
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
everton.euclides - Antwoord
jafarez -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 187
Altijd: 2,568
