Ga door naar hoofdinhoud
Anker SoundCore 2 Motherboard Replacement
Wat je nodig hebt
  1. Anker SoundCore 2 Motherboard Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Motherboard Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Motherboard Replacement, Motherboard: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: stap 2, afbeelding 3 van 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Motherboard Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Motherboard Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
Conclusie
Kristen Gismondi
77.584 Reputatie
184 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
16.243 handleidingen geschreven
3 opmerkingen
Where can I buy the C34 and ESD4?
Abel Omeokwe - Antwoord
Hello.
Do you know where to fond an Anker motherboard please?
Thanks
ckridene - Antwoord
Princelee Balasingham Prince - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 54
Altijd: 1,112
