Ga door naar hoofdinhoud
Anker SoundCore 2 Microphone Replacement
Wat je nodig hebt
  1. Anker SoundCore 2 Microphone Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Microphone Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Microphone Replacement, Microphone: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Microphone Replacement, Microphone: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Microphone Replacement, Microphone: stap 2, afbeelding 3 van 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Flip up the speaker mount panel from the speaker housing case.
  3. Anker SoundCore 2 Microphone Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Microphone Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Microphone Replacement: stap 3, afbeelding 3 van 3
    • Disconnect the microphone wire from the motherboard.
    • Use a spudger to pry the microphone out of the speaker mount panel.
    • The microphone is held in place with glue, so you may need to re-glue the new microphone onto the speaker mount panel.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 476
