Ga door naar hoofdinhoud
Anker SoundCore 2 Bluetooth Chip Replacement
Wat je nodig hebt
  1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: stap 1, afbeelding 1 van 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 1 van 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 2 van 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: stap 2, afbeelding 3 van 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 1 van 3 Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 2 van 3 Anker SoundCore 2 Bluetooth Chip Replacement: stap 3, afbeelding 3 van 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
  4. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: stap 4, afbeelding 1 van 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: stap 4, afbeelding 2 van 2
    • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
    • For help desoldering and soldering, follow this guide.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 54
Altijd: 1,089
