Ga door naar hoofdinhoud
Android tablet Nobis NB09 Screen Replacement
Wat je nodig hebt
  1. Android tablet Nobis NB09 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Android tablet Nobis NB09 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Android tablet Nobis NB09 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: stap 2, afbeelding 1 van 3 Android tablet Nobis NB09 Screen Replacement: stap 2, afbeelding 2 van 3 Android tablet Nobis NB09 Screen Replacement: stap 2, afbeelding 3 van 3
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: stap 3, afbeelding 1 van 3 Android tablet Nobis NB09 Screen Replacement: stap 3, afbeelding 2 van 3 Android tablet Nobis NB09 Screen Replacement: stap 3, afbeelding 3 van 3
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: stap 4, afbeelding 1 van 3 Android tablet Nobis NB09 Screen Replacement: stap 4, afbeelding 2 van 3 Android tablet Nobis NB09 Screen Replacement: stap 4, afbeelding 3 van 3
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Enea Osmann
158 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Lid van UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Leden
12 handleidingen geschreven
2Gids Commentaar
The digitizer replacement instructions was great. Thanks
steven warren - Antwoord
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,602
