Ga door naar hoofdinhoud
Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Battery Replacement: stap 2, afbeelding 1 van 1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
  3. Andoer HDV 107 Battery Replacement: stap 3, afbeelding 1 van 1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
Conclusie
Isaac Saron
516 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Isaacson Spring 2017 Lid van UMass Dartmouth, Team S2-G4, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 371
