Ga door naar hoofdinhoud
Andobil Easy Clip Car Mount Replacement
Wat je nodig hebt
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: stap 1, afbeelding 1 van 1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: stap 2, afbeelding 1 van 1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: stap 3, afbeelding 1 van 2 Andobil Easy Clip Car Mount Replacement: stap 3, afbeelding 2 van 2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: stap 4, afbeelding 1 van 1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: stap 5, afbeelding 1 van 2 Andobil Easy Clip Car Mount Replacement: stap 5, afbeelding 2 van 2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: stap 6, afbeelding 1 van 1
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: stap 7, afbeelding 1 van 1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: stap 8, afbeelding 1 van 1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: stap 9, afbeelding 1 van 1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: stap 10, afbeelding 1 van 1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Tavares
205 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 68
Altijd: 1,783
