Ga door naar hoofdinhoud
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
Wat je nodig hebt
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: stap 1, afbeelding 1 van 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: stap 1, afbeelding 2 van 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: stap 1, afbeelding 3 van 3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: stap 2, afbeelding 1 van 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: stap 2, afbeelding 2 van 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: stap 2, afbeelding 3 van 3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: stap 3, afbeelding 1 van 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: stap 3, afbeelding 2 van 2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: stap 4, afbeelding 1 van 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: stap 4, afbeelding 2 van 2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: stap 5, afbeelding 1 van 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: stap 5, afbeelding 2 van 2
    • Clean or lubricate the device if necessary.
Conclusie
David Taylor
151 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-34, Donnelly Fall 2014 Lid van USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Lid
1 handleiding geschreven
Één opmerking
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 52
Altijd: 6,693
