Inleiding
Use this guide to remove or replace the dust fan in an American Sanders EZSand Orbital Sander 07163A 2017.
Wat je nodig hebt
Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
Remove the driver pad from the sanding disc.
Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
Repeat the previous seven steps to remove the other two sanding discs before continuing.
With all three sanding discs removed, use a 4 mm hex key to remove four 25.4 mm-long screws securing the bottom cover and bottom weight.
