Ga door naar hoofdinhoud
American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement
Wat je nodig hebt
  1. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the sandpaper disc: stap 1, afbeelding 1 van 1
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement: stap 2, afbeelding 1 van 1
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: stap 3, afbeelding 1 van 2 American Sanders EZSand Orbital Sander 07163A 2017 Driver Pad Replacement, Remove the driver pad: stap 3, afbeelding 2 van 2
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
Conclusie
Adam O'Camb
177.633 Reputatie
418 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 76
Altijd: 2,451
