Inleiding
Use this guide to remove or replace the interlock assembly in a Clarke Floor Sander 07163A 2012.
Wat je nodig hebt
Use a 3/16" hex key or driver bit to remove the six 23.4 mm-long screws holding the two halves of the handle enclosure together.
Pull the wires connected to the interlock assembly straight out of their connectors.
After all wires are disconnected from the interlock assembly, remove the interlock assembly from the handle.
