Inleiding
Use this guide to remove or replace a driver pad on a Clarke Floor Sander 07163A 2012.
This guide shows the removal of just one pad, but the procedure for the other two pads is identical.
Wat je nodig hebt
Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
Remove the driver pad from the sanding disc.
