Ga door naar hoofdinhoud
AmazonBasics BTV1 Battery Replacement
Wat je nodig hebt
  1. AmazonBasics BTV1 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Battery Replacement: stap 2, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Battery Replacement: stap 3, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 3, afbeelding 2 van 2
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Battery Replacement: stap 4, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Battery Replacement: stap 5, afbeelding 1 van 2 AmazonBasics BTV1 Battery Replacement: stap 5, afbeelding 2 van 2
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Chris Shannon
1.039 Reputatie
5 handleidingen geschreven
USF Tampa, Team 14-2, Lacy Spring 2016 Lid van USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Leden
8 opmerkingen
donde consigo la bateria?
bnet_d72 - Antwoord
Nice job, Chris! Thank you.
David Printz - Antwoord
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Antwoord
Need information on where to get a replacement battery!
dan - Antwoord
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 3,069
