Inleiding
The drive motor is what powers the shredding teeth via the drive gears. The motor may burn out due to age or extended use. It is found attached to the main shredder housing holding the shredding teeth and the drive gears.
Wat je nodig hebt
Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
Één andere persoon heeft deze handleiding voltooid.
