Ga door naar hoofdinhoud
AmazonBasics B00Q3KFX8U Drive Gear Replacement
Wat je nodig hebt
  1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: stap 1, afbeelding 1 van 1
    • Remove the shredder assembly from the paper scrap bin.
  2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
  3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 3, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 3, afbeelding 2 van 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
  4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 4, afbeelding 1 van 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
  5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 5, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 5, afbeelding 2 van 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
  6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 6, afbeelding 1 van 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
  7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 7, afbeelding 1 van 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: stap 7, afbeelding 2 van 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Conclusie
William Foley
548 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-3, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-3, Miles Spring 2016
UMASSD-MILES-S16S1G3
2 Leden
Één opmerking
Where does one buy these gear parts?
opticdreams - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 1,305
