Ga door naar hoofdinhoud
Amazon Luna Controller Buttons Replacement
Wat je nodig hebt
  1. Amazon Luna Controller Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Buttons Replacement: stap 2, afbeelding 1 van 3 Amazon Luna Controller Buttons Replacement: stap 2, afbeelding 2 van 3 Amazon Luna Controller Buttons Replacement: stap 2, afbeelding 3 van 3
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Buttons Replacement, Faceplate: stap 3, afbeelding 1 van 1
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Buttons Replacement: stap 4, afbeelding 1 van 1
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Buttons Replacement: stap 5, afbeelding 1 van 2 Amazon Luna Controller Buttons Replacement: stap 5, afbeelding 2 van 2
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Buttons Replacement, Buttons: stap 6, afbeelding 1 van 2 Amazon Luna Controller Buttons Replacement, Buttons: stap 6, afbeelding 2 van 2
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Buttons Replacement: stap 7, afbeelding 1 van 2 Amazon Luna Controller Buttons Replacement: stap 7, afbeelding 2 van 2
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Buttons Replacement: stap 8, afbeelding 1 van 3 Amazon Luna Controller Buttons Replacement: stap 8, afbeelding 2 van 3 Amazon Luna Controller Buttons Replacement: stap 8, afbeelding 3 van 3
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cade Queen
537 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 161
