Ga door naar hoofdinhoud
Amazon Kindle Oasis 8th Gen Battery Replacement
Wat je nodig hebt
  1. Amazon Kindle Oasis 8th Gen Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 2, afbeelding 1 van 3 Amazon Kindle Oasis 8th Gen Battery Replacement: stap 2, afbeelding 2 van 3 Amazon Kindle Oasis 8th Gen Battery Replacement: stap 2, afbeelding 3 van 3
    • Work your way around the back panel to free all the clips.
    • There are 5 clips on the long and thickest side of the oasis, and none on the others.
  3. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 3, afbeelding 1 van 2 Amazon Kindle Oasis 8th Gen Battery Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
  4. Amazon Kindle Oasis 8th Gen Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, lift the orange bridge connector off.
    • Place the tweezers in between the battery and the end of the bridge and lift upwards.
  5. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 5, afbeelding 1 van 2 Amazon Kindle Oasis 8th Gen Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently wedge the spudger under the battery starting from the left side, and slowly work the spudger around the edge to loosen the battery from the tape. Be careful not to rip the thin foil on the back of the battery.
    • Only use ESD safe tools when working on internal components of your device such as a spudger or opening tool.
    • It is not advised to use a metal spudger, as you could puncture the battery.
  6. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery up using a spudger and use your fingers to slowly pull the battery off the adhesive.
  7. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 7, afbeelding 1 van 2 Amazon Kindle Oasis 8th Gen Battery Replacement: stap 7, afbeelding 2 van 2
    Koop
    • Using the tweezers, gently lift the tape off of the Power bridge connector. If a new unit comes with a new piece of tape, remove entirely, if not remove and place one corner lightly face down on a clean surface to be used again.
  8. Amazon Kindle Oasis 8th Gen Battery Replacement: stap 8, afbeelding 1 van 1
    • Once free of the adhesive and connectors, remove the old battery from the device.
    • Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
    • Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Mohamed Elzini
416 Reputatie
4 handleidingen geschreven
USF Tampa, Team S16-G5, Eyestone Fall 2017 Lid van USF Tampa, Team S16-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S16G5
4 Leden
16 handleidingen geschreven
23 opmerkingen
Grate explanation. where can I find the battery? couldn’t find it anywhere
thanks
ALON GAZIT - Antwoord
Hi.. this is very helpful. But where does one buy a battery? Amazon doesn’t seem to sell them?
Ree - Antwoord
Hi, same comment: great and interesting but I can’t find the battery anywhere…
fabdelaere - Antwoord
WTH is a spudger?
Jim Price - Antwoord
You can find the battery here
https://www.nextbatteries.com/products/a...
890 mAH Li-Polymer 3.7V 61.60 x 53.32 x 2.78mm
Nat Whilk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 25
Afgelopen 7 dagen: 332
Afgelopen 30 dagen: 1,531
Altijd: 44,126
