Ga door naar hoofdinhoud
Amazon Kindle 8 Front Cover Replacement
Wat je nodig hebt
  1. Amazon Kindle 8 Front Cover Replacement, Front Cover: stap 1, afbeelding 1 van 2 Amazon Kindle 8 Front Cover Replacement, Front Cover: stap 1, afbeelding 2 van 2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Front Cover Replacement: stap 2, afbeelding 1 van 2 Amazon Kindle 8 Front Cover Replacement: stap 2, afbeelding 2 van 2
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Luke
420 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 318
