Ga door naar hoofdinhoud
Amazon Fire TV Stick Remote Battery Replacement
Wat je nodig hebt
  1. Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: stap 1, afbeelding 1 van 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: stap 1, afbeelding 2 van 3 Amazon Fire TV Stick Remote Battery Replacement, Remote Battery: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to press into the seam between the remote and battery cover.
    • With the same tool to help pop the batteries out.
  2. Amazon Fire TV Stick Remote Battery Replacement: stap 2, afbeelding 1 van 1
    • Place two fresh batteries back inside the remote and slide the cover back on.
    • Ensure positive ends of the batteries both point towards the top of the remote.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrew Busse
870 Reputatie
2 handleidingen geschreven
IUPUI, Team 2-3, Harley SU 2016 Lid van IUPUI, Team 2-3, Harley SU 2016
IUPUI-HARLEY-SU16S2G3
4 Leden
13 handleidingen geschreven
35 opmerkingen
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - Antwoord
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber -
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - Antwoord
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Kelsea Weber -
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 67
Afgelopen 30 dagen: 232
Altijd: 116,703
