Ga door naar hoofdinhoud
Amazon Fire TV Remote Control Motherboard Replacement
Wat je nodig hebt
  1. Amazon Fire TV Remote Control Motherboard Replacement, Batteries: stap 1, afbeelding 1 van 2 Amazon Fire TV Remote Control Motherboard Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
  2. Amazon Fire TV Remote Control Motherboard Replacement: stap 2, afbeelding 1 van 2 Amazon Fire TV Remote Control Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
  3. Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: stap 3, afbeelding 1 van 2 Amazon Fire TV Remote Control Motherboard Replacement, Remote Control Motherboard: stap 3, afbeelding 2 van 2
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
  4. Amazon Fire TV Remote Control Motherboard Replacement: stap 4, afbeelding 1 van 2 Amazon Fire TV Remote Control Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
  5. Amazon Fire TV Remote Control Motherboard Replacement: stap 5, afbeelding 1 van 2 Amazon Fire TV Remote Control Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
  6. Amazon Fire TV Remote Control Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
  7. Amazon Fire TV Remote Control Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Alejandro Franco Ceron
739 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-3, Wollert Fall 2015 Lid van USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 Leden
16 handleidingen geschreven
3 opmerkingen
Hello,
step 5 is wrong! There are no pins but screws!
You need to disconnect the upper piece (infrared sensor) first. Underneath you will find two more screws. Then you can open the case easily.
TheAffenkotze - Antwoord
The circuit board can not be fixed instead of replaced. Understand might be cheaper to replace
Seymour Butts - Antwoord
This was useful to me to find a location I could attach a lanyard to the remote. It is so small it keeps disappearing.
Patrick Kniesler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 174
Altijd: 12,870
