Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will walk you through the step-by-step procedures to remove and replace the speaker in your Amazon Fire TV Cube. These steps are simple, however some require considerable force. To complete this replacement you will need a small screwdriver and opening tool.
  1. Using a metal spudger,  push down between the edge seals on the base and pry off the base. Do not confuse the top thin layer of rubber with the thick palette that needs to be removed. This may require substantial force.
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer. There are 4 washers to go with each of the screws. There are 4 washers to go with each of the screws.
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  4. Lift and remove the full frame.
    • Lift and remove the full frame.
  5. Lift and remove the speaker. Carefully match the outlets on the speaker with the outlets on the motherboard.
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 67
Altijd: 1,251
