Ga door naar hoofdinhoud
Amazon Fire TV Cube Motherboard Replacement
Wat je nodig hebt
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: stap 1, afbeelding 1 van 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: stap 1, afbeelding 2 van 3 Amazon Fire TV Cube Motherboard Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: stap 2, afbeelding 1 van 3 Amazon Fire TV Cube Motherboard Replacement: stap 2, afbeelding 2 van 3 Amazon Fire TV Cube Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: stap 4, afbeelding 1 van 2 Amazon Fire TV Cube Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Amazon Fire TV Cube Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: stap 6, afbeelding 1 van 2 Amazon Fire TV Cube Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: stap 7, afbeelding 1 van 2 Amazon Fire TV Cube Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Gently pry the motherboard up and off.
    Nobody anywhere has these motherboards so what good are instructions to replace. It’s like being given a car that doesn’t have keys and those keys can’t be made anywhere.
    futuregu - Antwoord
Conclusie
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
where do you buy the mother board ?
Sam Handa - Antwoord
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 1,619
