Ga door naar hoofdinhoud
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
Wat je nodig hebt
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: stap 1, afbeelding 1 van 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: stap 1, afbeelding 2 van 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: stap 1, afbeelding 3 van 3
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: stap 2, afbeelding 1 van 1
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: stap 3, afbeelding 1 van 1
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: stap 4, afbeelding 1 van 2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: stap 4, afbeelding 2 van 2
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Conclusie
Omir Rosado
725 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-4, Passmore Fall 2016 Lid van USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 586
