Ga door naar hoofdinhoud
Amazon Fire HD 10 Screen Replacement
Wat je nodig hebt
  1. Amazon Fire HD 10 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Amazon Fire HD 10 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Amazon Fire HD 10 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: stap 2, afbeelding 1 van 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: stap 3, afbeelding 1 van 2 Amazon Fire HD 10 Screen Replacement: stap 3, afbeelding 2 van 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the screen and digitizer from the case completely.
Conclusie
26 andere personen hebben deze handleiding voltooid.
Jaie Hillery
1.718 Reputatie
10 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Winter 2016 Lid van USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Leden
22 handleidingen geschreven
16 opmerkingen
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Antwoord
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Antwoord
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Antwoord
What is needed to attach the screen back to the case?
Jimmy Lee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 162
Altijd: 34,875
