Ga door naar hoofdinhoud
Amazon Fire HD 10 Rear Facing Camera Replacement
Wat je nodig hebt
    1. Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: stap 1, afbeelding 2 van 3 Amazon Fire HD 10 Rear Facing Camera Replacement, Screen: stap 1, afbeelding 3 van 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 10 Rear Facing Camera Replacement: stap 2, afbeelding 1 van 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Fire HD 10 Rear Facing Camera Replacement: stap 3, afbeelding 1 van 2 Amazon Fire HD 10 Rear Facing Camera Replacement: stap 3, afbeelding 2 van 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Fire HD 10 Rear Facing Camera Replacement: stap 4, afbeelding 1 van 1
      • Remove the screen and digitizer from the case completely.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: stap 5, afbeelding 1 van 2 Amazon Fire HD 10 Rear Facing Camera Replacement, Rear Facing Camera: stap 5, afbeelding 2 van 2
      • Remove the single T5 Torx screw at the base of the camera.
      • Once removed, place the screw aside in a safe location.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Fire HD 10 Rear Facing Camera Replacement: stap 6, afbeelding 1 van 2 Amazon Fire HD 10 Rear Facing Camera Replacement: stap 6, afbeelding 2 van 2
      • Lift the camera from the case using the plastic opening tool.
      • The camera is still connected to the motherboard via the ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Fire HD 10 Rear Facing Camera Replacement: stap 7, afbeelding 1 van 2 Amazon Fire HD 10 Rear Facing Camera Replacement: stap 7, afbeelding 2 van 2
      • Gently grab the camera and pull to remove.
      • The camera is now free from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jaie Hillery
1.774 Reputatie
10 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Winter 2016 Lid van USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Leden
47 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 1,248
