Ga door naar hoofdinhoud
Amazon Fire HD 10 Front Facing Camera Replacement
Wat je nodig hebt
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: stap 1, afbeelding 2 van 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: stap 1, afbeelding 3 van 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Front Facing Camera Replacement: stap 2, afbeelding 1 van 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Front Facing Camera Replacement: stap 3, afbeelding 1 van 2 Amazon Fire HD 10 Front Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Front Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 1 van 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 2 van 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: stap 5, afbeelding 3 van 3
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  6. Amazon Fire HD 10 Front Facing Camera Replacement: stap 6, afbeelding 1 van 2 Amazon Fire HD 10 Front Facing Camera Replacement: stap 6, afbeelding 2 van 2
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  7. Amazon Fire HD 10 Front Facing Camera Replacement: stap 7, afbeelding 1 van 2 Amazon Fire HD 10 Front Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  8. Amazon Fire HD 10 Front Facing Camera Replacement: stap 8, afbeelding 1 van 2 Amazon Fire HD 10 Front Facing Camera Replacement: stap 8, afbeelding 2 van 2
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jaie Hillery
1.718 Reputatie
10 handleidingen geschreven
USF Tampa, Team 16-6, Blackwell Winter 2016 Lid van USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Leden
22 handleidingen geschreven
Één opmerking
Can this camera module be upgraded with a better version?
Jimmy Kee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,117
