Ga door naar hoofdinhoud
Amazon Fire 5th Generation Battery Replacement
Wat je nodig hebt
  1. Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: stap 1, afbeelding 1 van 2 Amazon Fire 5th Generation Battery Replacement, Remove front screen assembly: stap 1, afbeelding 2 van 2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
    • Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
  2. Amazon Fire 5th Generation Battery Replacement: stap 2, afbeelding 1 van 3 Amazon Fire 5th Generation Battery Replacement: stap 2, afbeelding 2 van 3 Amazon Fire 5th Generation Battery Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using angled ESD precision tweezers, lift up on the battery cables to separate the battery connector from its socket.
    • Be sure to lift the battery connector cables themselves and not the actual socket. Doing this step incorrectly could damage the connector.
  3. Amazon Fire 5th Generation Battery Replacement: stap 3, afbeelding 1 van 3 Amazon Fire 5th Generation Battery Replacement: stap 3, afbeelding 2 van 3 Amazon Fire 5th Generation Battery Replacement: stap 3, afbeelding 3 van 3
    • Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
    • When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
    • Be careful not to bend the battery. Don't use too much force, as it can damage the battery.
    The replacement went smoothly and. while it is listed as Moderate Difficulty, I found it quit easy. Even with my 72 year-old hands, using the iFixit tool kit. It took me about five minutes from opening the case to closing it again.
    Cal C - Antwoord
    Worked like a charm. Started by the usb slot with it open as it was the easiest place to get a start.
    Richard Davy - Antwoord
Conclusie
23 andere personen hebben deze handleiding voltooid.
Maximilian Plavcan
1.202 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-2, Nance Spring 2016 Lid van USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 Leden
13 handleidingen geschreven
9 opmerkingen
Where do you purchase the replacement battery (and what part number)?
John LaRue - Antwoord
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
crimsontideaggie - Antwoord
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
Ashley Pollen - Antwoord
@stash115 Are you talking about the connector attached to the wires that are on the battery or the connector on the circuit board of the Fire?
Jeff G - Antwoord
The black connector on the circuit board
Ashley Pollen -
Updated link to battery: (only $5usd)
https://www.powerbookmedic.com/Amazon-Fi...
David - Antwoord
A couple of details: 1. The connector is removed in a direction perpendicular to the plane of the board. I found that the gentle application of a knife blade on the side away from the wires, followed by moving the blade away from the board, will do the trick. 2. The adhesive is a 1/4” strip around the edges of the battery. There is no adhesive elsewhere.
TheGear - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 177
Altijd: 21,431
