Inleiding
The Amazon Fire 5th generation uses a 2980 mAh rechargeable Lithium-ion Battery Pack. When replacing the battery pack, ensure that the proper safety and protective gear are used to avoid potential harm.
Wat je nodig hebt
Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
Gereedschap gebruikt in deze stap:Tweezers$3.99
Using angled ESD precision tweezers, lift up on the battery cables to separate the battery connector from its socket.
Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
23 andere personen hebben deze handleiding voltooid.
9Gids Commentaar
Where do you purchase the replacement battery (and what part number)?
Battery to buy right below!
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
