Ga door naar hoofdinhoud
Amazon Echo Tweeter Replacement
Wat je nodig hebt
  1. Amazon Echo Tweeter Replacement, Power and Speaker Driver Board: stap 1, afbeelding 1 van 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Replacement: stap 2, afbeelding 1 van 3 Amazon Echo Tweeter Replacement: stap 2, afbeelding 2 van 3 Amazon Echo Tweeter Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Replacement: stap 3, afbeelding 1 van 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Replacement: stap 5, afbeelding 1 van 2 Amazon Echo Tweeter Replacement: stap 5, afbeelding 2 van 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Replacement: stap 6, afbeelding 1 van 3 Amazon Echo Tweeter Replacement: stap 6, afbeelding 2 van 3 Amazon Echo Tweeter Replacement: stap 6, afbeelding 3 van 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Replacement, Tweeter Assembly: stap 7, afbeelding 1 van 2 Amazon Echo Tweeter Replacement, Tweeter Assembly: stap 7, afbeelding 2 van 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Replacement: stap 8, afbeelding 1 van 1
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Replacement: stap 9, afbeelding 1 van 3 Amazon Echo Tweeter Replacement: stap 9, afbeelding 2 van 3 Amazon Echo Tweeter Replacement: stap 9, afbeelding 3 van 3
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
  10. Amazon Echo Tweeter Replacement, Tweeter: stap 10, afbeelding 1 van 2 Amazon Echo Tweeter Replacement, Tweeter: stap 10, afbeelding 2 van 2
    • Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
    • Remove the tweeter from its plastic housing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Albert
1.169 Reputatie
6 handleidingen geschreven
3Gids Commentaar
Anyone know where to get a replacement tweeter?
Ryan Alexander - Antwoord
Could you kindly post the dimension and depth of this tweeter/full range unit? Thank you.
No Body - Antwoord
Can anyone provide me the spare tweeter of Amazon echo dot 3rd generation
Pravesh Bansal - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 6,352
