Ga door naar hoofdinhoud
Amazon Echo Show Speaker Replacement
Wat je nodig hebt
    1. Amazon Echo Show Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 2 Amazon Echo Show Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 2
      • Using your hands, gently remove the taped-in rubber foot from device.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Echo Show Speaker Replacement: stap 2, afbeelding 1 van 2 Amazon Echo Show Speaker Replacement: stap 2, afbeelding 2 van 2
      • Carefully peel off the bottom pad to expose the fastening screws.
      • Remove three silver 1.4 T5 Torx screws on the top row.
      • Remove one green 1mm T5 Torx screw in the middle.
      • Remove a black 1.5mm T5 screw.
      • Remove three green 1mm T5 screws from the bottom row.
      Vraag FixBot
      Voeg opmerking toe
    3. Amazon Echo Show Speaker Replacement: stap 3, afbeelding 1 van 1
      • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Amazon Echo Show Speaker Replacement: stap 4, afbeelding 1 van 2 Amazon Echo Show Speaker Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
      • Repeat this step for the other speaker, and lay the front section flat with the facing down.
      • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Echo Show Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 Amazon Echo Show Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 Amazon Echo Show Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
      • Use a non-magnetic T-6 screwdriver to unscrew the four 6mm screws on the speaker mount.
      • Repeat this step for the other speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Echo Show Speaker Replacement: stap 6, afbeelding 1 van 2 Amazon Echo Show Speaker Replacement: stap 6, afbeelding 2 van 2
      • Gently lift the speaker needing replacement from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Seems you missed an important step on here. How do you get the front off the box? Show how to remove the speaker grill, the grill cloth and then pry up the digitizer and screen. That’s where all the f***ing screws are!!! That’s how you get into this damned thing!! But you left all that ‘unimportant’ stuff out.
n3tqv - Antwoord Deel
Where do you get a replacement speakers
bluwolf224 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 7,024
