Ga door naar hoofdinhoud
Amazon Echo Show 5 Disassembly
Wat je nodig hebt
  1. Amazon Echo Show 5 Disassembly, Amazon Echo Show 5 Disassembly: stap 1, afbeelding 1 van 3 Amazon Echo Show 5 Disassembly, Amazon Echo Show 5 Disassembly: stap 1, afbeelding 2 van 3 Amazon Echo Show 5 Disassembly, Amazon Echo Show 5 Disassembly: stap 1, afbeelding 3 van 3
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
  2. Amazon Echo Show 5 Disassembly: stap 2, afbeelding 1 van 2 Amazon Echo Show 5 Disassembly: stap 2, afbeelding 2 van 2
    • Remove the three screws with a T6 Torx screwdriver.
  3. Amazon Echo Show 5 Disassembly: stap 3, afbeelding 1 van 3 Amazon Echo Show 5 Disassembly: stap 3, afbeelding 2 van 3 Amazon Echo Show 5 Disassembly: stap 3, afbeelding 3 van 3
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
  4. Amazon Echo Show 5 Disassembly: stap 4, afbeelding 1 van 1
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Zachary Buckler
710 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-4, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G4
3 Leden
14 handleidingen geschreven
1Gids Commentaar
pretty brief disassembly instructions but thanks
Admin Rinn - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 70
Afgelopen 30 dagen: 362
Altijd: 7,771
