Ga door naar hoofdinhoud
Amazon Echo Show 2nd Gen Sound foam Replacement
Wat je nodig hebt
  1. Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: stap 1, afbeelding 1 van 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: stap 1, afbeelding 2 van 3 Amazon Echo Show 2nd Gen Sound foam Replacement, Sound foam: stap 1, afbeelding 3 van 3
    • Make sure the device is unplugged and powered off.
    • Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
    • Pull each of the plugs out.
  2. Amazon Echo Show 2nd Gen Sound foam Replacement: stap 2, afbeelding 1 van 3 Amazon Echo Show 2nd Gen Sound foam Replacement: stap 2, afbeelding 2 van 3 Amazon Echo Show 2nd Gen Sound foam Replacement: stap 2, afbeelding 3 van 3
    • Use the metal spudger to pry and create space between the sound foam and the frame.
    • Once you have sufficiently pried the foam from the frame on each side, detach the sound foam from the frame with your hands.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,587
