Inleiding
This guide will walk you through the replacement process for the Motherboard found within your Amazon Echo Show 10 3rd Gen device. Refer to tweeter replacement guide as a prerequisite in order to get to motherboard.
Wat je nodig hebt
With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
Remove the lid and set it aside.
Remove the six 6.8 mm screws using a T6 Torx screwdriver.
Remove the metal bracket.
