Ga door naar hoofdinhoud
Amazon Echo Power and Speaker Driver Board Replacement
Wat je nodig hebt
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: stap 1, afbeelding 1 van 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: stap 2, afbeelding 1 van 3 Amazon Echo Power and Speaker Driver Board Replacement: stap 2, afbeelding 2 van 3 Amazon Echo Power and Speaker Driver Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: stap 3, afbeelding 1 van 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Power and Speaker Driver Board Replacement: stap 5, afbeelding 1 van 2 Amazon Echo Power and Speaker Driver Board Replacement: stap 5, afbeelding 2 van 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: stap 6, afbeelding 1 van 3 Amazon Echo Power and Speaker Driver Board Replacement: stap 6, afbeelding 2 van 3 Amazon Echo Power and Speaker Driver Board Replacement: stap 6, afbeelding 3 van 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Alexander Albert
1.145 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-3, Wollert Spring 2016 Lid van USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Leden
12 handleidingen geschreven
22 opmerkingen
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - Antwoord
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
same here...
D Nation - Antwoord
Where do I get a replacement board ?
Sean Burch - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 67
Altijd: 26,578
