Ga door naar hoofdinhoud
Amazon Echo LED/Microphone Board Replacement
Wat je nodig hebt
  1. Amazon Echo LED/Microphone Board Replacement, Power and Speaker Driver Board: stap 1, afbeelding 1 van 1
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo LED/Microphone Board Replacement: stap 2, afbeelding 1 van 3 Amazon Echo LED/Microphone Board Replacement: stap 2, afbeelding 2 van 3 Amazon Echo LED/Microphone Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo LED/Microphone Board Replacement: stap 3, afbeelding 1 van 1
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo LED/Microphone Board Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo LED/Microphone Board Replacement: stap 5, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement: stap 5, afbeelding 2 van 2
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo LED/Microphone Board Replacement: stap 6, afbeelding 1 van 3 Amazon Echo LED/Microphone Board Replacement: stap 6, afbeelding 2 van 3 Amazon Echo LED/Microphone Board Replacement: stap 6, afbeelding 3 van 3
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo LED/Microphone Board Replacement, Motherboard: stap 7, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo LED/Microphone Board Replacement: stap 8, afbeelding 1 van 1
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo LED/Microphone Board Replacement: stap 9, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement: stap 9, afbeelding 2 van 2
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo LED/Microphone Board Replacement: stap 10, afbeelding 1 van 3 Amazon Echo LED/Microphone Board Replacement: stap 10, afbeelding 2 van 3 Amazon Echo LED/Microphone Board Replacement: stap 10, afbeelding 3 van 3
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo LED/Microphone Board Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard up from the Echo.
  12. Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: stap 12, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: stap 12, afbeelding 2 van 2
    • Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
  13. Amazon Echo LED/Microphone Board Replacement: stap 13, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement: stap 13, afbeelding 2 van 2
    • Unclip and remove the top volume ring assembly from the Echo.
  14. Amazon Echo LED/Microphone Board Replacement: stap 14, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement: stap 14, afbeelding 2 van 2
    • Unscrew the four 9.7 mm T9 torx screws from the bottom of the volume ring assembly.
  15. Amazon Echo LED/Microphone Board Replacement: stap 15, afbeelding 1 van 1
    • Turn the assembly over and lift up the plate with the buttons.
  16. Amazon Echo LED/Microphone Board Replacement: stap 16, afbeelding 1 van 2 Amazon Echo LED/Microphone Board Replacement: stap 16, afbeelding 2 van 2
    • Turn the plate over, then lift and remove black gear and the white plastic ring.
  17. Amazon Echo LED/Microphone Board Replacement: stap 17, afbeelding 1 van 3 Amazon Echo LED/Microphone Board Replacement: stap 17, afbeelding 2 van 3 Amazon Echo LED/Microphone Board Replacement: stap 17, afbeelding 3 van 3
    • Remove the ribbon cable by lifting the brown latch on the ZIF connector.
    • Lift the LED/Microphone board from the plate.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Alexander Albert
1.145 Reputatie
6 handleidingen geschreven
USF Tampa, Team 3-3, Wollert Spring 2016 Lid van USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Leden
12 handleidingen geschreven
2 opmerkingen
So in Step 15, I’m having a problem reassembling the Plate with buttons back into the volume ring… can someone give me any tricks/pointers please?
JaxyB - Antwoord
Where can i buy this LED/Microphone board for replacement?
Tuan Nguyen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 56
Altijd: 13,931
