Ga door naar hoofdinhoud
Amazon Echo Dot 3rd Generation Casing Replacement
Wat je nodig hebt
  1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: stap 1, afbeelding 1 van 3 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: stap 1, afbeelding 2 van 3 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: stap 1, afbeelding 3 van 3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Casing Replacement: stap 2, afbeelding 1 van 2 Amazon Echo Dot 3rd Generation Casing Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Casing Replacement: stap 3, afbeelding 1 van 1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Casing Replacement: stap 4, afbeelding 1 van 2 Amazon Echo Dot 3rd Generation Casing Replacement: stap 4, afbeelding 2 van 2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
Conclusie
To reassemble your Echo Dot, follow these instructions in reverse order. Ensure the casing fits properly before tightening the screws back on. Once reassembly is finished, check that the device powers on and functions correctly.
Kristen Gismondi
99.777 Reputatie
255 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.752 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 1,156
